WaveRaider 1100 Reeds
Results 1 to 6 of 6
    Jun 2017
    MO
    http://shop.bansheedepot.com/Yamaha-...0-Reeds-91.htm
    I have run TDR reeds on all of my RZ350's and it seemed to help the throttle out a lot. Would these be any good in a waveraider 1100? Any jetting changes that need to be made?
    Jan 2006
    Smoky Mountains TN
    Re: WaveRaider 1100 Reeds
    Group K says no
    Group K says yes
    REEDS - The stock reeds and cages on these machines have consistently outperformed any aftermarket reeds we have tested. Some aftermarket reeds can offer better power for 20 - 30 operating minutes. However after that amount of time the material often "looses its memory" or begins to chip. As this happens, the performance offered by these weakened aftermarket reeds becomes worse than stock. If you do choose to purchase reed cages or petals from any aftermarket manufacturer, get an assurance that their in-house technicians will be able to help you with the carb tuning needed to get your engine running properly.
    http://www.groupk.com/y1100-1200.htm
    Jun 2017
    MO
    I'm looking at changing the petals not the whole Reed valve. From my RZ350 experience jetting isn't required for that it just helps with throttle response and a wee bit of power.
    Jan 2006
    Smoky Mountains TN
    Seems like you have talked yourself in to it in spite of Grop K experience that it is a bad idea - It's your time and money and ski so go for it
    Top Dog
    Feb 2013
    NorCal
    Didn't know TDR made reeds!
    PWCToday Regular destructive's Avatar
    NJ
    I have boysen in mine but also other mods done. In my application they gave better throttle response. I only ride the surf with it. They lasted me 3 seasons. I will be buying the same reeds again.
