1999 785 pro brand new from 1999 just puchased
Results 1 to 10 of 12
    PWCToday Newbie sublimehemi's Avatar
    Jun 2007
    chicago
    so team polaris ...i am now bit...interesting story behind this ski...not even a scratch in hull...brand new on its aluminum trailer it was sold on. its weird to see a 20 year old ski brand new especially this model....what do you guys think?
    Aug 2010
    delavan, wi
    Re: 1999 785 pro brand new from 1999 just puchased
    That's an awesome find. And you're so close too, I'm jealous.
    My pro is down for a while, rebuild crank, redo top end, parts not for another month.
    Post some pics of the inside. There may be faster skis now, but there's none that have that much power at that weight. There never will be ever again with everything going 4 stroke.
    90 Superjet, 98 Polaris Pro 785, 95/92 Kawasaki 750 sxi, 01 Polaris 600 sc xp
    Jun 2007
    chicago
    thank you pro785.....i will post many pics as soon as cleaned up....it is currently at my parents house until i make some room....i did not have the heart to leave outside.....its been in climate controlled storage its whole life....... i fell in love with ski...geez im almost too scared to ride....but you only live once right.....
    how much does this ski weigh dry?
    PWCToday.com Is My Home Away From Home beerdart's Avatar
    May 2005
    CT
    Oh my..
    Top Dog
    Feb 2013
    NorCal
    What is the story? Why did they buy it and store it without ever riding?
    Aug 2010
    delavan, wi
    Quote Originally Posted by sublimehemi View Post
    480lbs, 140hp. Make sure you run premium fuel only, and try and avoid ethanol gas.
    This thing will probably beat you up, you can trim it up all the way to take some of the bite out of it and it'll blow a big rooster tail a few feet high and about 50 feet back. But you should really try and get to the point you can drive it and use the trim effectively.
    When I ride hard I trim down in the corners and put my weight out and to the back. Might want some aftermarket sponsons at some point too, I have some Beach Houses on my pro and it really makes it stick even more. If you trim down too far it will just nose dive though and it has enough power and it's small enough that it'll just keep going underwater.
    Also make sure you do all the maintenance on it, specially tightening the exhaust manifolds. This is a super good resource https://sites.google.com/site/polarispwcknowedge/Home
    A very nice find.
    Resident Guru 785 lugs's Avatar
    Feb 2005
    chicago il.
    Very Nice
    Where you located in Chicago in the city
    Jun 2007
    chicago
    Quote Originally Posted by pro785 View Post
    thanks for this info....muchy appreciated....i have 110 octane at pump and like to know which 2 stroke oil to use....also....do iridium plugs work well in these?.....when i put iridium plugs in my waveblaster 2 760 , it ran so awesome...no sputtering ... easy starts...very smooth....better transitions...higher top speed...never fouled....
    i cant wait to drive this thing.....but i want to be very cautious..reading alot...
    Aug 2010
    delavan, wi
    I use Klotz for everything, always better to use expensive oil on these boats to keep them running, fixing them is not good. I have some pitting in a connecting rod and have to redo the crank. Can't get parts from one place, bearings from another cross referenced, rods from SBT, pistons from another, etc.
    You want to take good care of these things and keep them running good. Not to mention cheap oil will gum up the exhaust port valves and make them stick, and you'll be stuck cleaning them.
    People usually recommend the Polaris VES (might be something different now) or Klotz.
    Kinda neat there's three of us Pro guys in the Chicago area.
