Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: 750 x2 help
  1. #51
    Jun 2013
    Atlanta, Ga
    Re: 750 x2 help
    Are you sure you do not have any exhaust leaks?
    Did you ever put a new check valve on the tank? You can usually get a Yami check valve from ebay for 1/2 the price of a Kawi. Your tank should hold pressure, if you run the engine for a minute or so and unscrew the fuel filler it should burp.
  2. #52
    Dec 2009
    Buffalo
    Re: 750 x2 help
    Did you try turning the high speed screw in to only 1 turn out or half turn out?
  3. #53
    PWCToday Regular dsweeney18's Avatar
    Sep 2014
    New York
    Re: 750 x2 help
    I've tried all sorts of setting on the carb and yes I'm positive there is no exhaust leak I have triple checked.
  4. #54
    Jun 2013
    Atlanta, Ga
    Re: 750 x2 help
    Check valve on the tank? Is the tank building and holding pressure?
  5. #55
    Sep 2014
    New York
    Re: 750 x2 help
    Quote Originally Posted by Bob Gruen View Post
    Yes the valve in the tank is fine
  6. #56
    Jun 2013
    Atlanta, Ga
    Re: 750 x2 help
    Plug wires go bad and can act up under an increasing load. If both carb configs behave the exact same way I'd suspect ignition. Maybe one lead is dropping out, which would be easy to spot on the spark plugs if you chop it while the problem is happening.
    But, for a last sanity check I would run it on a trailer or tied to a dock. Remove the flame arrester, and watch the throat of the carb as you pull the throttle and the upper circuit kicks in. If you see a flood of fuel come out of the bomb sight, or no fuel at all, then it is a carb problem.
    Bob
