Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Thread: 750 x2 help
    May 2011
    miami
    Re: 750 x2 help
    I had a very similar issue to yours recently. I had ano oem kawasaki 650 exhaust manifold with a "factory pipe" exhaust gasket off ebay. The exhaust port opening was too large and water was spraying in. Ski topped out at 1/2 throttle. What kind of exhaust manifold do you have?
    PWCToday Regular dsweeney18's Avatar
    Sep 2014
    New York
    Re: 750 x2 help
    Quote Originally Posted by 2strokesmoke View Post
    I believe it is a stock 650 manifold but I'm not positive. It does look like the ones I have on my 650 blocks. I am using that gasket set I have posted a picture of previously and I have a factory head pipe on that.
    Where do you mean that the water is spraying in? Between the block and the manifold or between the pipe and the manifold? And how do I fix this?
    Mar 2016
    Central nj
    Re: 750 x2 help
    If you are running 750 electrics in this ski, is it possible that the overheat sensor wires are connected together or grounded and it's causing the ignition to run in limp-home mode?
    Just a thought.
    Sep 2014
    New York
    Re: 750 x2 help
    Quote Originally Posted by Keihin42 View Post
    Just a thought.
    Here's a question. The sensor is still hooked up but just strapped to the side and no water is running through it. Does it complete the circuit indicating an overheat to out it in 'limp mode' if there is no water running through it?
    May 2011
    miami
    Re: 750 x2 help
    Pic of gasket kit does not include the header pipe gasket. Post a pic if you can.
    Sep 2014
    New York
    Re: 750 x2 help
    It did not come with one I put a used 650 gasket on between the manifold and the pipe.
    May 2011
    miami
    Sep 2014
    New York
    Re: 750 x2 help
    Is there a way to verify the water in the exhaust is my problem without removing the pipe? And you're saying it's leaking in from between the manifold and the head of the pipe correct?
  9. #29
    May 2011
    miami
    Re: 750 x2 help
    Correct
    I did with my cheap bore scope. Disconnected the cooling from the pump and hooked it to the garden hose. Disconnected the line off the cylinder head to the header pipe and stuck it outside the hull. Then turned the hose of full blast. Or you could unbolt the header pipe remove the gasket and check for damage or signs of leakage.
  10. #30
    Sep 2014
    New York
    Re: 750 x2 help
    Correct
    If I did the hose trick you explained and it was in fact leaking there wouldn't it fill my block with water?
