Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
    PWCToday Regular mrwhipper's Avatar
    May 2017
    New Holland
    2001 GTI, no spark?
    Hello,I am using my fathers login.
    My father just bought me a 2001 GTI with a 717. When we bought it the previous owner had concerns about the oil pump not working. The previous owner put new spark plugs in the and it would start fine. My father and I tested the oil pump to make sure that it function properly. Before we started to test the pump, we disconnected the spark plugs and put the wires on the grounding posts. After we completed checking the pump we reconnected the spark plugs and it would not start. After diagnosing with a timing light, it does not have any spark.
    Are there any ideas of what is wrong, or how to diagnose the problem that we are experiencing?
    That you for all of you consideration to helping find a solution to our problem.
    Jun 2011
    Re: 2001 GTI, no spark?
    How did you check for the no spark condition?
    I use an inline spark checker with a little light in it to tell me if I have spark or not.
    What would Chuck Norris do?
    Sep 2015
    Northern Michigan
    If you have no spark I would check all the fuses first. If you don't have the shop manual you can download it for free, there are trouble shooting sections in them.
    May 2017
    New Holland
    Quote Originally Posted by Cliff View Post
    {Dad replying}
    I used a timing light and pulled a plug to check for spark.
    May 2017
    New Holland
    Quote Originally Posted by Hydro-Mike View Post
    {dad replying}
    I have a shop manual and looking in Section 3 but all it says is replace MPEM. I know that the previous owner has just replaced it.
    May 2017
    New Holland
    So, I guess my next question is how do I test the MPEM? I also did some searching and on other threads some were saying that the stator could be the problem. How to I test the stator?
    Sep 2015
    Northern Michigan
    That would be where I would look.
    May 2017
    New Holland
    Not sure what you are saying. Continue to search? Replace the MPEM? Replace the stator?
    Jun 2011
    Quote Originally Posted by mrwhipper View Post
    {Dad replying}
    Was there spark?
    May 2017
    New Holland
    Was there spark?
    No spark nor no light.
