Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
    I dream skis Bionic racing's Avatar
    Idaho/California
    Re: 2001 GTI, no spark?
    Pull rear sub box check for rust and water contamination , coils are in there , have a known good MPEM with lanyard if needed , stators are pretty tough on sea slugs
    Jun 2011
    Here are the pages from the manual for your year/make/model to test the ignition system:
    If at first you don't succeed...
    Then you're NOT Chuck Norris!
    PWCToday Regular mrwhipper's Avatar
    May 2017
    New Holland
    Thank you all so much for your help so far. So here is where we stand. I do not have mag harness adapter so my assumption is that it is a connector for the mag wires with pig tales for testing. (if I am incorrect please let me know. I was able to push my multi meter connectors in the back of the connector. With the connector connected using the black and the black and red wires I got 27 ohms and while trying to start I got 6 AC volts. The spec is for 40 - 76 ohms and 18 to 25 VAC. If I disconnected the connector I did get 58.5 ohms but of course I could not crank the engine. (that is where my assumption came from with the adapter.
    So, assuming again........ Generating coil??????
    Jun 2011
    You are correct with the adaptor as it only makes it easier to disconnect the pigtail and plug in the adaptor and use the butt connectors to access reading from the magneto.
    If those are the readings. It looks like it might be the coil. So move onto the test procedure for that component and see what you measure.
    Sep 2015
    Northern Michigan
    Quote Originally Posted by Hydro-Mike View Post
    That would be where I would look.
    Look at testing the stator ( doesn't cost anything.)
    May 2017
    New Holland
    Oh. I thought i just did test it. What do I do to test it?
    What am I missing? In the manual I did the static and dynamic tests.
    Thanks.
    May 2017
    New Holland
    I removed the flywheel and noting obvious. Should I order a new stator?
    May 2017
    New Holland
    I should have asked this yesterday. With my MM should the selector be in the position that it is in the pic or at the 200 to check ohms per the manual?
    Thanks!
    Jun 2011
    Needs to be in the 200 range.
    It's currently in the diode check position.
    May 2017
    New Holland
    OK I will run out and re check it. THANKS!!!!!!!!!
