Anyone put a two seater on a hitch hauler? Pictures? Advice?
Results 1 to 10 of 11
    PWCToday Regular demian5's Avatar
    Jul 2012
    lake forest, ca
    Hi I have a 95 xp800 and I am thinking I want to haul it on a hitch hauler.
    Anyone haul a 2-seater on one?
    Any pictures or advice?
    1995 Seadoo xp800 787x - Stock (hauls a** just as it is!)
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Re: Anyone put a two seater on a hitch hauler? Pictures? Advice?
    The problem is most trucks have class 3 receivers
    "Class III hitches used as weight carrying are rated up to 6000 lbs. gross trailer weight (GTW) with a 600 lbs. maximum trailer tongue weight"
    Then with that much weight over hanging you need to have some beefed up suspension on the truck or air bags.
    Jan 2006
    Smoky Mountains TN
    If you have a force of 100
    lb acting at a distance 10 feet from the fulcrum or pivot point, the
    torque is 100 lb times 10 feet = 1000 foot-pounds. If you double
    either the force (weight) or the distance ("lever arm"), you double
    the torque.
    That ski weighs 430lbs dry = easy 500+ with oil and gas
    You would be near the limit of a classIII hitch IF all the weight was at the hitch (pivot point)
    BUT because your weigh will be spread out over a 3 or 4 ft distance away from the hitch (Pivot point) the hitch hauler will be acting as a lever - The torque effect of that lever will result in a weight WAY over the limit of your hitch. Example 500lbs x 2 ft = 1000 ft lbs of torque
    If you try it be sure to adjust your headlights so you don't blind pilots / aircraft
    Jul 2012
    lake forest, ca
    So it would be pressing down more than my toy hauler?
    My truck is rated at 800lbs max tounge without Weight-Distributing Hitch.
    Frequent Poster AirJunky's Avatar
    Sep 2015
    Liberty Lake, WA
    Quote Originally Posted by demian5 View Post
    Hopefully you don't just have a class 3 receiver on that truck.... which is what most trucks have.
    Bill
    Current ride is an almost stock 94 550SX
    Current project is a 92 Super Chicken SC650
    My JS550 build
    . - SOLD
    Jul 2012
    lake forest, ca
    Quote Originally Posted by AirJunky View Post
    Class IV
    Dec 2011
    Niceville, FL
    In addition to the weight issue there is width to consider. How wide can a vehicle be? I hauled one on the front of a double trailer that I converted to a triple and I pulled the nozzles off for the ride because it was really filling the lane up.
    Aug 2011
    Texas
    I have a one ton truck with a class V hitch but I still wouldn't want to do it. As stated, the weight is going to be so far behind the hitch receiver that it will have LOTS of leverage. At best you may loose a PWC, but in doing so you may cause other vehicles to be involved in an accident.
    '16 Seadoo GTX155 / depth finder, ski pylon and ski mode module added
    '18 Kawasaki STX15F
    Jul 2012
    lake forest, ca
    Great info.
    Aug 2015
    Birmingham
    I'd expect my hitch to handle it, I would wander about the carrier tho
