97 Tigershark Loss of power above half throttle
    Apr 2017
    seattle
    My Ski: 1997 Tigershark 1000 Monte Carlo
    Symptoms:
    - Won't go above 10-15mph.
    - Runs better and faster slightly below half throttle than it does above half throttle.
    - There is a noticeable difference in sound and speed once you get to half throttle.
    - It is also a little hard to start and barely holds idle.
    - If I pull the choke while the ski is running, it instantly dies.
    What I've done:
    - Perfect compression (The entire engine was rebuilt recently).
    - Thoroughly cleaned, rebuilt, and shot compressed air through the carbs. Multiple, multiple times. They are clean. Every nook and cranny.
    - New spark plugs
    - Replaced all the fuel lines.
    - Replaced fuel pump.
    - Replaced fuel filter.
    I'm out of ideas and just about ready to give up. I feel like it isn't getting enough fuel. Any ideas? Does this sound like reed valves?
    Cottage Grove, MN
    Re: 97 Tigershark Loss of power above half throttle
    Quote Originally Posted by meowman View Post
    No. Reed valves rarely ever fail on their own. Check for spark on all cylinders. Sounds like it's in limp mode/not running on all cylinders.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    97' Daytona 1000 sold
    99' TS770R sold
    PWCToday Regular Supra01's Avatar
    Jun 2013
    Munford
    Just wanted to share what happened to me !! My tiger shark is a 95 Daytona anyway I done built carbs built fuel pump or well you know I bought the separate parts anyway come to find out my fuel problem was the hose that goes into tank!! Now I'm not sure how yours is but but mine has a nipple threaded into tank with a hose and on end of hose there is a metal piece that keeps hose in fuel or weighted down !! Well anyway that piece fell off hose inside of tank and the fuel line would float on top of gas and anyway it done exact same thing !! Just thought I would give an idea And keep in mind I'm.no professional but thought I'd give an idea
    Pull and check the exhaust hoses. Sometimes they blister inside and collapse. Its like a banana in the tailpipe.
    Cypress, TX
    "a metal piece that keeps hose in fuel or weighted down " is called a Clunk Weight Fuel Clunk Weights.jpg
