Results 11 to 12 of 12
    Frequent Poster banjomaniac's Avatar
    Jul 2009
    nc
    Re: Test motor when its out of the ski
    Ok, I went to Harbor freight with a 25% off coupon and bought a leak down tester BUT it doesn't have an adapter that fits so anybody know the size and or where I can get an adapter to fit?
    Thanks, banjomaniac
    Jul 2009
    nc
    I have just now gotten time to test a few things and I pulled the manifold and closed all water hoses off but 1 and it tests good. I cant get water to flow and it builds up pressure until I release the hose, I also pulled the capped off water lines 1 at a time to let water through then recapped it all and tried again, it is good to go. I'm going to try and sell this engine as a whole, I think this thing is good being the manifold is good, the turbo that I put on my ski is good and the waste gate isn't stuck. I can crank it around with a pry bar and the oil residue I can see inside is clean. If it gets parted out I'll let you know.
    Banjomaniac
