Results 1 to 10 of 12
    Jul 2009
    nc
    Test motor when its out of the ski
    I bought a used r12x motor complete with the computer is there any way to test this out of the ski or is there any way to test the computer itself?
    Frequent Poster Lee Taylor's Avatar
    Sep 2013
    Charleston SC
    Re: Test motor when its out of the ski
    Different brand and model but based on this video I would say yes you can test it out of the ski
    Owner. Rider. Maintenance. 15yrs.
    2002 Yamaha. FX140. 1000cc. Cruiser. Collectors model.
    2017 Lowes Stryker 16. Mercury 50hp 4-stroke.
    Video: https://www.youtube.com/playlist?lis...CHDiKr9UqpdsAV
    Top Dog west_coaster's Avatar
    Apr 2005
    San Diego CA
    Bolt the motor to a pallet using the motor mounts and some good bolts.
    Not sure how much of the wiring harness would be needed to enable the computer to provide spark and such, might need the displays hooked up.....no idea. But you'll need a fuel pump at a minimum.
    05 F-12X
    Jul 2009
    nc
    Actually I just got the motor off the skid out of the back of my truck and it has two of the engine mounts the other two are not there. I'm going to have to build a base for it to set on to get it evened up. It doesn't have any oil in it but I pulled the turbo off and the turbo looks good no shaft play, the residue oil in the turbo looks clean and it spins nice and the wastegate is free and moves like it should. I gotta wonder why this engine was pulled? Im sure there was a reason. Next I'll pull the plugs and see if the motor is free or locked up and try and put oil in it, maybe get some compression readings.
    Banjomaniac
    Apr 2005
    San Diego CA
    If you have the capability to do a leak down test, that would be way more informative than a compression test. Plus you won't have to spin the motor over meaning no wiring/battery necessary.
    05 F-12X
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    You'll just have to rotate the crank by hand to close the valves but that won't be hard with the plugs out. Are you trying to check the motor or the ECM?
    07 Honda F12X Saphire Blue
    MacBoost, Large intercooler, solas intake grate and impeller.
    03 Honda F12X Red
    05 SeaDoo GTX 4-tec Supercharged
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X,
    Need to have:
    F15X
    Jul 2009
    nc
    Both but I'm looking at the motor right now, I have no idea what the condition of this motor is, the guy called me and said he traded for it and a yamaha 62t so I bought both. He knew nothing about them or whats wrong with them. I'll pull the plugs and see if it's locked up. It doesn't have any oil in it.
    Banjomaniac
    Apr 2005
    San Diego CA
    Does it have a good exhaust manifold on it? I need one and they're on national backorder.
    05 F-12X
    Jul 2009
    nc
    Not sure about the manifold, since the wastegate is free and looks good I'm guessing it might be good. If I get a chance I'll pull it off and do a water test.
    Banjomaniac
    Sep 2013
    Charleston SC
    Sounds like you are going to have to go through the entire engine. Because the suspicion is that there is something significantly wrong with the engine that is unknown but lurking in there somewhere. If you are not on a schedule it could prove to be enjoyable.
