    Jul 2003
    MA
    Pop off PSI for 97 900 ZXI
    Anyone know the pressure for a 97 zxi 900?
    PWCToday Newbie barlosbhz's Avatar
    Aug 2015
    brazil
    2
    Re: Pop off PSI for 97 900 ZXI
    31 psi on the 3 needles. I changed my 3 needles and put new 1.6. I got this measurement and skiing is working perfect.This one with standard pistons.
    Jul 2003
    MA
    I ended up lower. I think it was 26 PSI.
    I am only on the second tank of gas after the rebuild.
    I noticed that the bottom end and top end bog a little. I am still running premix along with the injection. I was going to wait until I was running straight gas and new plugs before I try tuning but now I am so what concerned it is the pop off pressure.
    Frequent Poster a1cnc's Avatar
    Jun 2017
    NH
    I screwed with my pop off pressure ALOT this season. Lower higher right in zee middle. My bottom end bog I cured eventually with richer pilots and leaner screw setting and a pop off ~25-32 psi. Top end bog would be controlled by main jet. It depends on if it's rich or lean.
    Can you describe what it does?
    1998 ZXI 1100 Red
    1994 Polaris SL750 $50 I couldn't help myself!
    I suffer from JOCD!
    Jet-ski Obsessive compulsive disorder
    Jun 2017
    NH
    BTW, Where are you riding? I am looking for someone to ride with.
    1998 ZXI 1100 Red
    I suffer from JOCD!
