Carb identification
Results 1 to 6 of 6
    May 2017
    ny
    Carb identification
    Hey guys I need some help identifying these carbs I've recently purchased for my seadoo 720 it's a 46mm mikuni annular discharge type carb with what looks like a mid range jet that has been drilled and added into, I'm running them with 2 internal fuel pumps until I get an external one I'm having a hell of a time getting these things to work at all
    I have a factory pipe ve head and an r&d intake with open f/a I'm curious if anyone has any experience with these carbs before thanks for any help guys
    Dec 2014
    Re: Carb identification
    Looks like a sbn. It prob has a Low speed, high peed, and pilot jets.
    PWCToday.com Is My Home Away From Home BigKahuna's Avatar
    Nov 2001
    Tuscaloosa, AL
    it's an SRE. Similar to a blackjack except a mid 3rd circuit jet has been added.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    May 2017
    ny
    Any recommendations on jetting using that 3rd jet?
    Dec 2011
    Niceville, FL
    Just leave the third jet and change the highs and lows as needed. What kind of pipe are you going to run?
    May 2017
    ny
    I have a factory pipe that will be hard jetted till i get a controller I just don't get it since it will run good then just drop off and run on one cylinder then it will take off and half way throttle cut out again
