Results 1 to 6 of 6
    Sep 2007
    In the water
    R&D head sealing issue
    I have a R&D head o-ring style 750/800 27cc domes. I took off the head to see if the head was sealing both combustion chamber and water cooling. I used 1211 sealant around the head with the o-rings. O-rings sealed the combustion chamber fine but the 1211 sealant never contacted the cylinder deck. Had I ran water through it it would have leaked out of the head reducing cooling to the pipe.
    My question is can I run a oem metal gasket instead of using the o-rings. I think this will lower compression but at 27cc I can handle a reduction in compression. Will I loose sealing properties specifically with the combustion chamber allowing water into cylinders?
    What are your thoughts?
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Sep 2007
    In the water
    Re: R&D head sealing issue
    I bought the o-rings from R&D. Could they be to big in diameter to allow the cooling portions of the head to contact the deck properly?
    Right now the R&D head is not torgued down enough so I am losing compression as is with the orings.
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    We have a yammy rd rec head, it sealed up fine, we ordered both of the std orings from McMaster Carr, one size fit well. No hg
    Dec 2009
    Buffalo
    You shouldn't need to use sealant, find some marine grease and when installing the O-rings, use a little to seal the ring into the head as it will also help keep it in there while installing.
    Feb 2002
    Vancouver, BC Canada
    The 750 R&D head must use sealant as it only has o-rings around the combustion chambers.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Oct 2006
    under a ton of work
    ^^x2 and the head surface is slightly convex to compress more around the combustion chamber so r&d uses 1211 to seal the cooling portion.
