1990 Square Nose SuperJet Build - Page 3
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
    Jun 2017
    illinois
    Re: 1990 Square Nose SuperJet Build
    To be honest I need to check to see if it even has an after-market one already in it. what do you recommend for ompeller or is it depending on certain mods on your ski?
    Nov 2011
    Wisconsin
    Quote Originally Posted by lextreme View Post
    If you're on a budget, a stock blaster 1 prop works well. Well enough for $30 but you will get some cavitation.
    1991 Superjet
    2014 Superjet
    Michigan
    Any stainless aftermarket impeller will be a major improvement. Impeller pitch and brand are kind of personal preference depending what you want the ski to perform like. Solas YB-CD Concord 14/18 13/17 is a good all around option.
    Jun 2017
    illinois
    Off subject.. anyone have any experience having a full motor shipped?! If so, from what shipping company and how much did it cost?.. found a minty fresh (freshwater)61x but it's in Utah...
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    I have had a small pin shipped to me for 50 or 60$ usps
    Jun 2017
    illinois
    Quote Originally Posted by Jhucke View Post
    MSD coils are junk. Go with used stock Kawi coil.
    Just get a used adjustable rev limit 61x cdi. Especially with a new MSD box, spotty quality. It's your money to blow though.
    Are you implying that 701 motors are not "tanks"? because they are.. your 650 is not any more or less reliable than a 701. It's also a power lacking waste of time.
    You need the short block, exhaust manifold, intake.. that's it. I bet you could do it for 500 or close to it.
    If price is a non-issue, there is 0 reason to stay with a 650.
    Well you were pretty close.... complete engine minus exhaust(came out of a vxr pro) .. comes with ebox and even carb... 150/150 compression = asking $550 plus shipping
    still trying to figure out how much shipping will be..
    also found this in the for sale section.... Is $500 a good price for this or should i look around some more? What is the 2" welded in extension for?
    May 2007
    The plus 2 is for more bottom.
    Nov 2011
    Wisconsin
    As long as stuff is clean and you have the cash, I say it's worth the money all day long especially if you plan on doing more modding.
    The 2" is supposed to be for extra low end but I've never ran a pipe like that without the added section so I have nothing to compare it to. Either way, you'll like the power I'm sure.
    1991 Superjet
    2014 Superjet
  9. #29
    Jun 2017
    illinois
    61x engine assy is on its way... working on a exhaust
  10. #30
    Jun 2017
    illinois
    If I did go with the protec mach 1 exhaust, would I need to replace anything else to run it? I know i will have to rejet the carb but would i need a girdled head or anything else?
