Results 1 to 10 of 10
    resident guru G_man's Avatar
    AZ
    Fuel injector cleaner ok to use?
    RXP
    When it's first put in the water it will not get above 3000 RPM it wants to die out.
    So I rode it around HARD for about 20 minutes trying to get it to higher RPM.
    Slowly but surely I was able to do that and the mile per hour increased this has happened the last few times.
    I'm thinking the fuel injectors might be getting clogged as it has not been ridden that much this summer.
    Stable was put in it before the last ride thanks for your help.
    Jan 2006
    Smoky Mountains TN
    Re: Fuel injector cleaner ok to use?
    Start with new spark plugs - it should be your first step.
    Aug 2011
    Logan Martin Lake, Lincoln, Alabama
    Yamaha RING FREE! Hate to mention on seadoo forum but, that stuff is the s###! Will clean rings, clean all carbon from valves, lube the top end and clean the injectors. Plan on changing oil after you run it through.. I use a "shock" treatment: 2oz for 10gals fuel. Does real well for the plugs but they're to easy to change. Also comes in an spray can that you can spray in the throttle body. I buy the plugs and change after I'm done. Good Luck!
    Top Dog madd_dips's Avatar
    Mar 2009
    Miami Beach
    What year rxp?
    Aug 2011
    2-2010 gti se 130.
    Aug 2011
    My bad wrong post
    AZ
    2008 rxp
    AZ
    Quote Originally Posted by aeolian View Post
    Thanks for the reply do they stock the stuff in the Yamaha shop or do I need to order it?
    Mar 2009
    Miami Beach
    Quote Originally Posted by G_man View Post
    2008 rxp
    Pm sent.
    Aug 2011
    sorry taken a while to get back They stock it,
