    PWCToday Newbie Flynnstone's Avatar
    Sep 2010
    Oregon
    1999 GSX RFI No spark
    This ski is driving me nuts. I am getting no spark. Tested another coil no spark. I get 12v from Red wire going into coil when start pressed and 12v from both white wires when start pressed. Tried another crank sensor. Curious is the crank sensor is actually the pickup for the coil/spark. Any help would be greatly appreciated.
    PWCToday Regular mrwhipper's Avatar
    May 2017
    New Holland
    Re: 1999 GSX RFI No spark
    Did you test on the other side of the coil using a timing light?
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    mrwhipper: Do you use an induction timing light and how do you test it. Do you test both the positive and the ground with the timing light? If so, how specifically?
    May 2017
    New Holland
    Quote Originally Posted by E350 View Post
    Yes. detector clamp on stator plug wire, pos light wire to the pos on battery, neg light wire to the neg on battery then crank the engine.
