    Jun 2015
    earth
    2015 vx110 code 163
    Hello. I just bought a 2015 vx cruiser with 4 hours on it. The machine starts and shows code 163 with check engine blinking and beeping
    Does anyone know what this code means ?
    SE CT
    Re: 2015 vx110 code 163
    Its for the scu. Is your reverse gate blocked?
    R.I.P. Super Sic
    Jun 2015
    earth
    Went to go start it today everything is fine. Dealer said it has something to do with low voltage.
    Dec 2007
    st pete beach florida
    i have seen that problem before with weak battery, voltage going down to 10v and slow start, charging system was kicking up to 15.2 volts while reving up to try to compensate battery discharge, remember electronic system is voltage sensitive, make sure you have a good fully charged agm battery to start with.
