750 swapped X2 what prop to run?!
    PWCToday Regular TexomaMan_X2's Avatar
    Dec 2014
    Texas
    I have a 1991 kawasaki X2 with a 750sx swapped drilled and tapped with 650 flywheel and electronics. Its 1mm over and im running a westcoast exhuast mani port matched to a b pipe with a limited blaster chamber to a 2in TRD baffled waterbox. I advanced timing to 2 degrees with a 44mm r&d intanke with 44mm sbn. What prop do i need to make this thing rip? Im a noob in the prop area and what stuffer to use with the prop in the 650 pump? Help would be greatly appreciated!
    Let the good times roll
    Top Dog motodemon8's Avatar
    Jul 2012
    ILLINOIS
    Re: 750 swapped X2 what prop to run?!
    sxr 800 prop cut to 650 pump works pretty good for me
    YEAAAAAAAAAAAAAAAH BOOOOOOOOOOI
    Top Dog bandit88's Avatar
    Green Bay WI
    That might be too steep with only a single 44.
    -95 750SXI
    -90 TS650
    -91 300SX
