    Jul 2003
    Menifee, CA
    Pop Rivets for Side Rails
    I need to replace the side moldings on both of my 2005 Honda F12-X PWC. They appear to attached with pop rivets. Can anyone tell me what size pop rivets to use? I have the Honda repair manual and though it mentions the rivets, it doesn't talk about their dimensions. I know I can probably measure the existing rivets, but I was hoping someone else may have already done this and can offer some insight.
    Thanks in advance,
    Pat in Menifee, CA
    2009 Mandalay 43A Diesel Pusher
    2011 Toyota Tacoma V6 4WD Access Cab.
    '13 Honda GL1800A + Uni-Go Trailer
    '03 Honda 400Exs (2)
    '05 Honda F12-Xs (2)
    '16 Yamaha YXZ100R
    Top Dog spatera's Avatar
    Jul 2006
    South Ga
    Re: Pop Rivets for Side Rails
    When I replaced my moulding I went with stainless screws in place of the rivets that worked perfect.
    03 Honda F12X (my favorite) Red of course
    Used to have:
    98 GP760, 97 GTX Sea Doo, 97 GP1200, 02 Honda F12X, 2-03 Honda F12X, 05 SeaDoo GTX Supercharged
    Need to have:
    F15X
    Jun 2003
    JACKSONVILLE FL.
    The SS screws/nuts, like Steve said are the way to go. I tried the rivets and they never turned out good.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    '98 Allison Grandsport/Merc 2.5 SS
    Jax. Fl.
    Jul 2003
    Menifee, CA
    Are you using self-tapping screws, or machine screws with nuts? Thanks for the replies.
    Pat in Menifee, CA
    '16 Yamaha YXZ100R
    Jan 2006
    Smoky Mountains TN
    I used #8x1/2 stainless sheet metal screws - got them from Lowes or Home Depot - Didn't have to be self tapping as I used my electric drill with screw driver bit - My drill has adjustable torque which I set low so it would bottom screw without stripping - You want a flat or pan head so trim insert can slide in without hitting the screw head
    I dream skis skidoc's Avatar
    May 2012
    tampa
    Brian Brocksmith
    813-786-4418
    http://jetskisint.com
    Free Aquatrax Tech support
    https://www.facebook.com/pages/Jet-S...91943504243227
    Jul 2003
    Menifee, CA
    The project's finished. I ended up using pop rivets. The existing holes were rather large and I felt more confident using pop rivets rather then screws. Surprisingly, the hardest part of the project was reinstalling the vinyl strip into the moulding! I appreciate everyone's responses.
    Pat in Menifee, CA
    '16 Yamaha YXZ100R
