Results 11 to 20 of 23
    Jun 2011
    Re: Need help 1998 seadoo gtx limited rpms surging
    Correction... connections are labeled ABOVE the black rubber boot on the fuel baffle. But BELOW the fuel line connections(nipple) in the white/yellow plastic housing.
    Check the lines because you said you changed the fuel lines and things can get easily connected in the wrong order.
    How about the carb fuel line connections? Are they connected correctly as well?
    What would Chuck Norris do?
    May 2017
    Ohio
    Quote Originally Posted by Cliff View Post
    I'm thinking that the/a fuel line(s) are incorrectly connected.
    Be sure to trace out the lines from the fuel baffle(the connections are labeled in the plastic below the black rubber boot) to the carbs.
    Checked hoses they are right, baffle is clean, fuel pet**** is clean. No change
    The fuel valve is the biggest source of restriction. Go right from reserve to carb & see what happens.
    europe
    Also What brand rebuild kits did you use ???
    what exactly is wrong with the aftermarket ones and does that apply to all of them ??
    If its not Genuine Mikuni then they are junk.
    europe
    yes ...thats what i 've read all over the place ...but never an explanation / reason WHY !?
    Jun 2011
    The aftermarket diaphragm nipple or tab is too long as opposed to the Mikuni diaphragms.
    The aftermarket needles don't seal as well as the Vito's tipped needles.
    This all equates to flooding, hard starts and bogging.
    europe
    i use oem needles and rep kits out of LHC .....and did not yet xperience ur symptoms !?
    Jun 2011
    You didn't experience those symptoms because you used genuine Mikuni kits.
    I don't know what "LHC" is. So I can't answer that.
    Another symptom of junk N/S are fitment issues. I just found this out first hand yesterday as I used a genuine Mikuni kit. But opted for aftermarket needle & seats. The o-ring is to thick and does not push in and seat correctly. Even after using oil, spit and an Allen head socket.
    Like Grumpy said...
    Junk.
    Some people you just cant teach,so you get what we have here...FAILURE
