Allen head pivot bolt R&D turn nozzle seadoo pump
    Sep 2007
    In the water
    Does any one where to source this Allen bolt for a drop/turn nozzle setup. I lost one of the bolts that holds the turn nozzle on. Top bolt at 12 o'clock, bottom bolt at 6 o'clock.
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Apr 2006
    Oregon
    Re: Allen head pivot bolt R&D turn nozzle seadoo pump
    Might have to get the whole nozzle assembly on eBay or whatever unless someone here coughs one up?
    Home of Newmiller Machine
    Mar 2010
    Down by the river
    If you can get the thread pitch, and dia and length of the shoulder section on the one you have (they're probably the same, or see how it fits and adjust as required) and google search for "shoulder bolt" with those dimensions. Fastenal, Grainger & McMaster Carr all carry that kind of stuff. I'm just guessing at sizes, but a search for M8 10mm X 10 mm shoulder bolt gets some decent hits....
    Fastenal stainless cap head shoulder bolt
    Grainger has truss head shoulder bolts in some english sizes
    Or maybe cut a piece of tubing to length as a bushing & use a standard pan head or truss head screw?
