Fx1 cutting out
Thread: Fx1 cutting out
    PWCToday Regular corwin06's Avatar
    Jun 2014
    minnesota
    Fx1 cutting out
    Hey guys seeing if you had any feedback on this current problem I'm having on my fx1, basically after about 1/3 throttle it feels like it's hitting a rev limiter. I assumed it was cavitation so I took the pump apart replaced the impeller new bearing and seals and it's still doing the same thing. The weirdest part is that sometimes it will go back to normal for a split second then I get on the throttle again and some sort of rev limiter is there. The ski ran great one day then the next day I come to ride it and this started happening I have a parts ski a wet jet duo 300 so I'm thinking of just swapping the e box and see if that takes care of the problem. Thanks in advanced for any help
    Js 550- west coast pipe, k&n intake, bigger carb, quick steer
    Jun 2014
    minnesota
    Re: Fx1 cutting out
    I also should add it starts right up and idles great, and even easing into the throttle it will still cut out
    Jun 2014
    minnesota
    Re: Fx1 cutting out
    Replaced the rectifier and the coils still doing the same thing
    Jun 2014
    minnesota
    Re: Fx1 cutting out
    pulled carb off and took it apart everything looked good, checked the reed valves they looked good as well replaced the CDI with one from my parts ski (wet jet duo) will try it this week and see what happens
    Jun 2014
    minnesota
    Re: Fx1 cutting out
    Finally got to test it, bad CDI box runs great now
