Factory pipe cracked expansion chamber flange-need advice
Results 1 to 6 of 6
    Sep 2007
    In the water
    750 wet pipe.
    Flange on expansion chamber for silicone coupler cracked where it was originally welded in production.
    Should I have this welded or use jb weld. I have filed it down and can see the start and stop of the weld
    Let me me know what y'all think is the best option.
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    PWCToday Guru TaintlessEd's Avatar
    Oct 2016
    Lake Elsinore
    Re: Factory pipe cracked expansion chamber flange-need advice
    I think jb would hold but if it were mine I'd bring it to a shop and tell them how you want it to be fixed.
    Don't ask them if they can fix it, tell them how to fix it.
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Quote Originally Posted by TaintlessEd View Post
    I like this. Anyone in a production environment recognizes a never fail mindset. If you don't give an option of failure it happens much less
    That will be very expensive to fix. It will take a couple hours of cleaning first to get it ready to weld. All that carbon caked oily mess will contaminate the weld. They will charge you plenty for that, clean it first. I would soak it for a day in solvent or degreaser first to break down the oil. Then clamp it to something and powerwash it. Then bead blast eveything within a few inches of the area needing repair. Then heat it up with a propane torch and wash off with brake clean and repeat to sweat out any remaining oils from the metal. Then finally its ready for welding.
    Sep 2007
    In the water
    I don't like the idea of jb weld. Might hold for short but then a pita to clean it up for welding.
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Sep 2007
    In the water
    Thx. That's the advice I'm looking for.
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
