Need help identifying where these water lines go.
    Jun 2004
    Lansing, MI
    I have a 97 Tigershark Daytona 1000 and need help figuring out where to water line hoses go. One water line comes in from the big water filter (3rd picture) in the back and connects to the lower left side (exhaust side) of the engine (2nd picture). Is that correct? Is this hose routed on exhaust side or on the carb side? The second hose I can't figure out where it goes. I think where the hose T's it connects to the purple expansion pipe and maybe the other end goes to the water box (1st picture)? If anyone knows where these hoses go please let me know.
    98' Sea Doo SPX Mint
    96' Sea Doo HX Mint
    95' Sea Doo XP800 Mint
    My Jet Ski videos below.
    Cottage Grove, MN
    Re: Need help identifying where these water lines go.
    The cooling system is very very very very (you get the point) simple. The hose coming off of the water filter plugs into a nipple on/near the flywheel housing. The other hose with the small T in it is the return line. The T plugs into the end of the purple expansion pipe, the other end plugs into a nipple on the water box. The heads plug into the exhaust manifold with three small hoses.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Monte Carlo 900 sold
    97' Daytona 1000 sold
    99' TS770R sold
    Jun 2004
    Lansing, MI
    Thanks! That is exactly what I had thought, but wanted to make sure. My project Daytona 1000 started out in pieces so sometimes it can be difficult piecing the small detail items back together.
    96' Sea Doo HX Mint
