Results 11 to 13 of 13
    Jun 2017
    North Dakota
    Re: 1991 Kawasaki 300SX engine swap
    Quote Originally Posted by Rushford_Ripper View Post
    Lots of work to swap......Rhaas products I hear is currently making a swap kit though.
    Rush do you know what kind of motor the kit uses to swap into the 300?
    Dec 2009
    Buffalo
    I don't, contact Robin at Rhaas products and ask
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    I've read a couple posts from people putting a 550 into a 300sx. They used a 1/2" aluminum bars mounted to the hull, then drill and tap into the bar for the 550 mounts. This would work perfectly for larger engines with the 650 adapter plate.
    It was recommended that the bottom of the hull be reinforced with a few layers of fiberglass to prevent cracking in the hull, as the hull wasn't designed to handle the horsepower of the larger motors.
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
