Results 1 to 10 of 13
    Jun 2017
    North Dakota
    1991 Kawasaki 300SX engine swap
    I am wondering if anyone out there has some knowledge about this? Is there any engine that will bolt into a 300sx hull without doing glass work?
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: 1991 Kawasaki 300SX engine swap
    I think a 550 goes in pretty easily. Everything else is going to be more work.
    -95 750SXI
    -90 TS650
    -91 300SX
    Jun 2017
    North Dakota
    So a 650sx engine is not something easy to swap in? Also does anyone know a way I can keep my oil injection system intact with a different engine?
    Oct 2014
    Oregon
    There is no easy swap for a 300sx. Whatever you decide to swap in originally came with oil injection. You would want the original oil pump from the donor engine.
    Jun 2017
    North Dakota
    Thanks for the info, did a 650sx come with oil injection?
    PWCToday Newbie Gremlin0701's Avatar
    Nov 2014
    Connecticut
    The 300sx has a different coupler also then like a 550 or even a js300
    Jun 2017
    North Dakota
    What engine would be the easiest then? Something where I would not have to do glassing or change the pump. I am very new to all of this, I love my ski I just want a bigger motor.
    Jun 2017
    North Dakota
    I would like to stick with a waterbox as well. I just need some incite. I have access to a cnc lathe, mill, and plasma cutter so if I have to do some fabricating that is okay with me. If anyone could chime in some info that would be great!!
    Jun 2017
    North Dakota
    Dec 2009
    Buffalo
    Lots of work to swap......Rhaas products I hear is currently making a swap kit though.
