Results 1 to 6 of 6
    Apr 2017
    NE Arkansas
    Water up to Flywheel in 99 GSX-L
    Got some water in my 99 GSX-L , auto bilge pump brought level down to motor mounts (lowest I could mount pump). Rode it the rest of the day, water stayed at that level (hitting flywheel).
    The vacuum bailers didn't take the rest of the water out.
    Took it home and checked the lines, one was kinked behind the VST motor, but the other one was clear, and held vacuum when I caped the white tube in rear of pump and held closed the tiny hole in the 90 degree fitting.
    What else can I check?
    Jun 2011
    Re: Water up to Flywheel in 99 GSX-L
    Here's a few items you can start to check/do:
    - Be sure the bailer hoses/tubes are mounted at the highest point the hose can be mounted(normally mounted above the exhaust hose)
    - check the rubber accordion boot at the right side of the pump at the rear of the ski on the VTS trim rod for tears and be sure the clamp is a smooth banded clamp and NOT a worm gear clamp with slots for grip as it will tear the boot and cause leaks
    - worn carbon ring not seated flush with the floating ring
    - casting plugs(round welded caps) on exhaust pipe are leaking from a failed weld(common)
    - cylinder drain tubes(on the back/lower rear of the cylinders) are not secured with zip ties/clamp or is partially disconnected
    - black plastic nut isn't tightened down enough or rubber washer from the VTS unit in the rear (at the trim rod) is pinched or has failed(rubber dries out and cracks causing water leaks)
    - clamp(s) on cooling lines on head are loose or failed
    If Ya find the problem. Report back and tell Us what you found, please.
    What would Chuck Norris do?
    Resident Guru SURFnTURF's Avatar
    Sep 2004
    AUSTRALIA
    Quote Originally Posted by HarleyPHD View Post
    The stock bailers are rubbish,they fill up with crud eventually and don't suck any water out.
    Install a set of 2006+ Seadoo drain plugs that come out of the 4 tec machines
    They work much better and completely remove all the water from the hull as they sit at the bottom and at the very rear of the hull
    Mar 2010
    NC
    You got a part # on the 2006+ 4 tec drain plugs. I like em
    Sep 2004
    AUSTRALIA
    Part # 292001075, you need to ream out the existing fiberglass hole in the rear a little with a file but they work great
    Apr 2017
    NE Arkansas
    No water this time out. Replaced kinked bailer hoses, still had water, drilled small hole in electric bilge pump discharge hose at highest point, no water. My 99 GSX-Limited has a factory bilge discharge hose outlet below the water line. I think it was siphoning water into the hull. The small bleed hole I drilled in the highest loop of the hose broke the siphon.
