Best Kind of Orings for head
Results 1 to 9 of 9
    Top Dog bandit88's Avatar
    Green Bay WI
    Im in need of new Orings on my badbones 750 head. Not sure what kind I should get. Should I go with a high temp silicon or a chemical resistant viton or some other type?
    -95 750SXI
    -90 TS650
    -91 300SX
    Mar 2005
    Santa Barbara, Ca.
    Re: Best Kind of Orings for head
    Viton
    Oct 2013
    funky town
    As Bruce stated, and everyone told me, too, Viton is the bees knees.
    I'm only here to make you mad
    Green Bay WI
    thanks guys. That's what I will order
    -95 750SXI
    -90 TS650
    -91 300SX
    Jul 2012
    milwaukee
    Where can you order them from, and how do you know what size to order. Thanks
    Green Bay WI
    I ordered them from McMaster Carr. Just measured the grooves in the head. All you need is the thickness and ID.
    -95 750SXI
    -90 TS650
    -91 300SX
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Part numbers are on the h2o site
    Green Bay WI
    -95 750SXI
    -90 TS650
    -91 300SX
    Oct 2013
    Ohio
    If you have a good Hydraulic Hose or Parker distributor in your area, they have typically have all the o'rings you can imagine.
    https://www.parker.com/literature/OR...g_Handbook.pdf
