    Frequent Poster 89KAW650's Avatar
    May 2009
    Reno
    SBN block off plates
    I put in a high volume fuel pump for my dual SBN 44's and installed the plates to get rid of the stock fuel pumps. My question is, what gasket / o-ring do i use with the plates? I used just the o-ring in there and they leaked bad out of the plate. Also, has anyone had issues with the plates fitting? The RHAAS plates i got didn't fit and had to be filled on the sides to fit the space? i installed the plate right to the carb without any of the old pump plates..Does the check valve plate need to be there also?
    thank you!
    Re: SBN block off plates
    You mount just the plate, with the o-ring gasket. Leave out all fuel pump parts IF you have leaks, there is a problem with the plate, and or your gasket.
    email watcon@watcon.com
    Please visit our web sites
    May 2009
    Reno
    Hats what I thought, but figured I'd check in case I missed something. I'll start with new o-rings and see if that does it.
    Top Dog bandit88's Avatar
    Green Bay WI
    I have used the mikuni plates before. Just installed them with the usual oring that goes in the carb body. Never had a leak. If you still have issues I would send Robin a message and see if he can send you another set.
    -95 750SXI
    -90 TS650
    -91 300SX
