98 seadoo gsx limited intermittent starting issue tried everything - Page 2
Results 11 to 20 of 21
    Sep 2013
    Midlothian
    Re: 98 seadoo gsx limited intermittent starting issue tried everything
    No, once the engine is running there is absolutely no issues. Only happens when i put key on and try to start
    Sep 2013
    Midlothian
    Any ideas??? It is totalled at this point in my opinion
    Sep 2013
    Midlothian
    It's good to know how useless this forum really is
    There is a slight possibility its losing main power through a corroded fuse holder in rear box or even the wiring itself. If the rear box and fuse holder are clean with no corrosion i would ohm each end of the wiring going into the rear box and perform the wiggle test. Could have a broken wire inside the insulation. I just replaced a wiring harness this weekend on an '08 yamaha because of broken/bad wires intermittenly not powering the fuse center.
    Sep 2013
    Midlothian
    That's a good call. I have only verified power and ground at mpem with multimeter. Could have a weak ground bc of coroded wiring. Although it looks good, I will run new ground to mpem and power wire from 15 amp fuse. Thanks for your input, I have been getting frustrated with this ski as you can tell lol
    Sep 2013
    Midlothian
    Screenshot_20170719-130255.pngwhen I unplug that carburetor solenoid the problem goes away. When I plug it back in, no start...
    Jun 2011
    If you post this info in the Sea Doo Section under the Technical Discussion. You will have much more exposure to this problem leading to much more possible fixes.
    What would Chuck Norris do?
    Dec 2011
    Niceville, FL
    I've been here with a 98GSX and never found it. I replaced everything (harness, MPEM, etc.). If you pull the 6 pin out of the mag cover it will spin over smooth.
    Feb 2004
    Glendora, California
    Have you tried replacing the Buzzer ? It'd be nice to verify/eliminate any DESS post connection issues from the mix.
    Last edited by Watercraft Magic; 09-02-2017 at 10:00 PM. Reason: censorship of buzzer ***'y
    Dec 2011
    Niceville, FL
    I used a 98GSX MPEM in one of my builds and it does this now.
