Dreaded code 25 on 2005 F12X with135 hours
    Jul 2006
    NE Georgia/WNC
    Hi,
    As my title says, I have "the code". I've read everything I can find here, but still not clear. Do I chance it and replace the knock sensor or go straight to a new ECM?
    Lastly, where is the best place to purchase either or both?
    Anyway to borrow an ECM to determine if that's the issue?
    thanks
    2005 Honda F-12X
    Lake Chatuge
    Hiawasse Ga/Hayesville NC
    Jun 2013
    Richmond, Virginia
    Re: Dreaded code 25 on 2005 F12X with135 hours
    Reach out to Jetski International for advice and parts. Do a search in this forum. If are willing to drive to Richmond with the ski, you can try my ECU and/or knock sensor.
    Chris
    2017 Yamaha GP 1800 (Riva stage one re-flash and intake, Candoo Pro GPS)
    2007 Honda F-12X GPScape w/ MACSBoost Plug-in Module and Intercooler
    2013 Cobalt 232 w/ 350 Mag and Bravo 3
    PWCToday Newbie texas4play's Avatar
    Jun 2017
    Texas
    I'm in the same boat with a 2002 Aquatrax F12 ....already tried the knock ....no go ....searching for ECU as we speak
    Jul 2017
    High rock lake nc
    I just bought a new ecm for my 05 f12x my local Honda dealer discounted for me. It's most likely the ecm.
    Jun 2017
    Tanoa FL
    Quote Originally Posted by Manniefresh View Post
    Jet Ski International has great information on their site on the dreaded 25 code and I talked to Brian there as well. Says well over 90% of the time its the ECM. So I have mine ordered. I thought worse case scenario, if mine is not bad, its inevitable that it will be. So I started with the ECM and will go to the knock sensor if I am in the very low %. He did say they would test the ECM for $100 if you send it in. Again, my thought was on a 13 yr old ski (2005 model but only 30 hrs) I am going to need it some day anyway, put the $100 towards the part!
    Jul 2006
    NE Georgia/WNC
    Quote Originally Posted by wveers98 View Post
    Thanks. Ugh.
    Do you have the part number?
    2005 Honda F-12X
    Lake Chatuge
    Nov 2016
    Louisiana
    Just go to http://jetskisint.com/ and search your year and model of your ski, cause they all different ecm.
