stock impeller ts1000
    Sep 2008
    San fran bay area, ca
    so today i went to granite bay, there was allot of debree in the water butthere were like 20 skis out there no probs.. first outing, a sleeper under water about 1.75in thionk stick got sucked up into my impeller and been the hell out of it...!
    so i need to pick up a SS impeller but i wanna keep it as close to original aluminum impeller as possible.. ski is completely stock. so what pitch sould i pick up?
    90' 550SX "Shaved head, .5mm+ Wiseco pistons, SBN 44, Kerker exhaust, Mariner waterbox, WestCoast OS Gas Tank, extended ride plate,(440 pump) 16deg SS Skat imp."
    WIP - 83' JS550 " .5mm+ Wiseco pistons, WestCoast: Head, rc520 reed cyl, 7 Ring Exhaust, Ext Ride plate, Ex Manifold, 2x Velocity stack, waterbox, Westcoast Dual 38 intake, Dual SBN 38s, 440 pump and a 16.5 degree SS Skat imp. Lightend flywheel"
    97' Tigershark Monte Carlo 1000 fresh top end and runs finally! ---SOLD---
    Frequent Poster Associated98's Avatar
    Cottage Grove, MN
    Re: stock impeller ts1000
    The way pitch is measured is different to every impeller manufacturer. Solas for instance wants a stock shark to run a 17.5/19.5 super camber impeller with the exception of the 99 tsr 1100 and 1100li. Stock almost every model came with a slightly different impeller. For a brand new impeller i would highly recommend the solas tb-sc-17.5/19.5. your stock impeller is a 19.5/23 with part number 0675-142. Again even though on paper the numbers are different, every single manufacturer produces those numbers differently. Let me know if you have any questions ill be happy to provide more info.
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    94' Montego (my first) sold
    95' Daytona sold
    95' Daytona parted out
    95' Barracuda sold
    96' Montego sold
    96' Daytona (the one that got away...) sold
    96' Monte Carlo 900 sold
    97' Daytona 1000 clean and beautiful. You will be missed.
    97' Daytona 1000 sold
    99' TS770R sold
    Sep 2008
    i cant find it on ebay they all 15.5/19.5
    could you quickly help me find right one with link, please and thank you so much. it was completely dumb luck that a large chunk of wood mangled stock impeller.
    only one i can find.
    http://www.ebay.com/itm/Solas-Super-...NZV9VE&vxp=mtr
    Cottage Grove, MN
    My apologies, you found the correct impeller i just remembered the pitch being different. Should have double checked before posting. That impeller will work just fine. Here is a link to an Impeller chart on solas's website
    http://www.solas.com/newweb/pwcprodu...asp#TIGERSHARK
    Own:
    98' TS1000R
    97' Daytona 1000
    97' Daytona 1000
    97' Daytona 1000
    Owned:
    95' Daytona sold
    95' Barracuda sold
    96' Montego sold
    99' TS770R sold
