PROJECT SXR / 900ace (thread redo) - Page 8
Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 155
  1. #71
    PWCToday Regular Fenix169motox's Avatar
    Nov 2008
    Northcoast
    Re: PROJECT SXR / 900ace (thread redo)
    Did you weigh it with the water in the tank? Do you know that water weighs about 2 pounds more per gallon than gasoline?
    Chester
    I'm well aware of the weight difference. But I don't get why it's relevant here. There has never been water in my fuel tank and the weight measurement I took was before I put it in the test tank
  2. #72
    Feb 2002
    Vancouver, BC Canada
    I'm sorry, I misunderstood. The way it is written, I thought you put the water in the gas tank to weigh it. My bad.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
  3. #73
    Top Dog RIDEH2O's Avatar
    Jun 2011
    nevada
    Lining stuff up on the bottom. Gotta get all the nut-certs and threaded things glued in
    for the rideplate, intake grate, pump, etc.
    Plus about 10 other glued mounting points inside for various brackets and hold downs.
    One last hurdle....making the top and bottom hull mate up nicely. I do have it worked out (in my head) lol
    2017 Jet Jam Racing "Region 2" Sport GP Champion
    Thanks 2017 sponsors....
    Lets do it again in 2018
    Reno KTM
    DirtTricks
    Reno / Tahoe Watercraft Connection
    Hunt & Sons / VP Racing Fuels
    Garate Enterprises (The Powder Man)
    On the Mark Construction, Reno NV
  4. #74
    Jun 2011
    nevada
    All glued threads for mounting points, done...I think?
    All under stuff lined up, shimmed, temporarily bolted. Pump shoe set to angle of pump and siliconed in place. Remember, I had to angle the pump down about 2* to line up with the driveline.
    But I have nozzle shims to correct that.
    Thank you ProWatercraft Racing for the silicone glue....left over from putting front sponsens on my other SXR. This project will get front and rear sponsens, from them, also!
    Also smoothed out the hole in the tunnel where the driveshaft goes to the motor. Man, that's a big hole! As long as we are air tight, shouldn't be a problem???
    Reno KTM
    DirtTricks
  5. #75
    Jun 2011
    nevada
    Ha, forgot I did the rideplate, too.
    Had to cut an oblong hole for the knuckle on the Solas pump trim system. But I think everyone has to do this for a Solas.
    Reno KTM
    DirtTricks
  6. #76
    PWCToday Guru matt888's Avatar
    Apr 2005
    CENTRAL FL
    Way cool project can’t wait to see the final product.
    SOLD! HONDA AQUATRAX 2 SEATER
    1987 JS440 SUPERSTOCK
    1988 JS440 FREESTYLE
    1987 JS550 LIMITED
    SOLD AND MISSED VERY MUCH, 1994 WAVEBLASTER LIMITED
    WWW.HONDAOFWINTERHAVEN.COM
    1987 AM. WORLD CUP CHAMP
  7. #77
    Jun 2011
    nevada
    Always a little harry scary drilling these types of holes! Are they lined up?, Are they in the correct spot front to back?
    Are the handlebars dead nuts center in the tray?
    I hope so!!
    Spent most of the day getting the top and bottom halves of the hull matching up perfect. So it was nice to do the handle pole at the end.
    A little more research to do. Gotta figure the best way to keep the halves water tight.
    Reno KTM
    DirtTricks
  8. #78
    whut in tarnationnnnnn
    look at it go!
    1994 1100 SJ - Dead
    1996 spec hx
  9. #79
    Jun 2011
    nevada
    Quote Originally Posted by 88kawi5fiddy View Post
    look at it go!
    It's a little early in the week to be drinking, K-fiddy!
    Put the bottle down, go back to your thread, mount your ebox, and throw me another reply on thursday.....lol
    Reno KTM
    DirtTricks
  10. #80
    Jun 2011
    nevada
    Ok, so here goes the plan....
    Used rubber pipe tape on upper hull to keep special epoxy from sticking to it.
    Then I put temporary foam gasket around perimeter to keep epoxy from running into hull.
    I put the two halves together, upside down. Clamped them in "finished position". Added epoxy to spaces between upper and lower
    halves around the bondline. Epoxy will stick to lower halve, but not upper half, due to rubber tape...(I hope!)
    When I split the haves tomorrow, I will remove the temporary weather stripping/foam and rubber tape, clean up any epoxy tailings, and replace with a special
    closed-cell rubber gasket.
    Now, in theory, the two halves should bolt together tight and solid, for rigidity, but have a giant "o-ring type" gasket around the perimeter.
    Kinda how an ADA head bolts to the top of cylinders....
    Reno KTM
    DirtTricks
