Results 1 to 2 of 2
    Jul 2009
    nc
    Reverse buclet repair kit
    I ordered a reverse bucket kit from Brian. I installed it and no change. Maybe I'm missing something but I pushed out the old plastic bushings and drove out the metal insert and the new ones were TIGHT. my guess is the bolt might not be the right one, seems like it should have less threads and more shoulder so you can tighten it all the way but maybe I don't understand the purpose of the plastic end and the metal other than keeping it from wearing out but if the bolt tightens on the bucket it will never move easily?
    Banjomaniac
    Jul 2009
    nc
    Re: Reverse buclet repair kit
    Ok, instructions should be included, it's obvious how it goes together BUT before you put the bushings in, take some sand paper and run it in the hole to get rid of all the corrosion. The bushings should slide in easily, not sloppy but after they are in the metal insert should be lose and spin inside the bushings freely.
    Banjomaniac
