Crank No Start No Spark Troubleshooting Decision Tree '94 701 SN SJ - Page 4
Results 31 to 34 of 34
  1. #31
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Re: Crank No Start No Spark Troubleshooting Decision Tree '94 701 SN SJ
    Myself: Copy that. I usually don't cheap out, but I want to look at it, test it, and try it. And good or bad, I will post up the results.
    Learning Slowly...
  2. #32
    May 2013
    Norcal
    Did you end up getting it running? What was the problem?
    Personally I would not use any non-OEM parts. JetSkiSolutions or JetManiac on x-h2o are a good source for rebuilt parts like stators.
    Your 1994 ski is a 61x engine and I'm sure JetSkiSolutions tested your coil when they rebuilt it so that is probably not the issue.
    Where on the Delta do you usually ride? I've ridden around there a few times.
  3. #33
    Jul 2015
    I burned out the lighting coil by running two bilge pumps.
    Will be sending entire stator in to JetSkiSolutions.
    Will install the Chinese stator for fun, but work is too much time for now.
    Learning Slowly...
  4. #34
    Jul 2015
    UPDATE AND CORRECTION: I thought I burned out the Lighting Coil on the stator by running two bilge pumps (and I just removed the front bilge pump to avoid doing just that), but after Corey at Jet Ski Solutions looked at a photo of my stator and had me do some digital volt meter tests on it, he deduced that it was a bad CDI.
    As advised by Corey I ordered a MSD Enhancer CDI for the 650/701 Super Jet and bam! it started right up!
    Learning Slowly...
