Results 1 to 9 of 9
    Jan 2010
    Ft.Lauderdal FL
    04 f12x overheats and loss of power
    My brother owned the ski for about 10 years and it sat 4 about 6 years I finally got it for next to nothing and I got it started the actuator I replaced on a turbo because it was rusted and I finally got it running and it only goes to 40. It now overheats. Should i take the intercooler out and exhaust mani to clean the water jackets. And why wont it go faster. Cant see throwing this thing out
    PWCToday Guru NunoP's Avatar
    Portugal
    Re: 04 f12x overheats and loss of power
    wellyou better start with the overheating problem.
    Overheating where?
    do you get a code?
    2004 F12X
    Jul 2009
    nc
    What does the exhaust manifold look like, I have a hard time beleiving it's not corroded after that long? But did you pull all the water lines and make sure they are clear? As far as the intercooler, pretty sure you can leave it on and just pull the hoses off and try to blow through it, running water through it doesn't necessarily tell if it's clogged gotta blow through it.
    Banjomaniac
    PWCToday Newbie FDNYMEDIC's Avatar
    Jun 2012
    Central Florida
    My 07 just started doing that also.. runs rough after about 2 min. Then shuts off.
    No code.
    Any ideas or suggestions appreciated..
    03 Honda F-12X
    07 Honda F-12.
    Jul 2009
    nc
    Here is the way to check for problems and also problems stored in the memory...
    SELF-DIAGNOSTIC PROCEDURE
    Fit the safety lanyard clip to the base of the engine
    stop switch.
    If the warning light and PGM-FI malfunction indica-
    tor lamp (MIL) do not blink, the PGM-FI system has
    no problem.
    If the MIL and warning light blink, and the warning
    buzzer sounds, the PGM-FI system has a problem.
    Push the SET, MODE, ID SET or ID NO. switch for
    more than 2 seconds to stop the warning buzzer.
    Push the SET and MODE switches simultaneously
    for more than 5 seconds to blink the failure code.
    Read and record how many times the MIL and
    warning light blinks and determine the cause of the
    problem (page 8-13).
    To read the ECM memory of problem data, perform
    the following:
    Pull the safety lanyard clip off of the engine stop
    switch.
    Remove the seats (page 3-4).
    Remove the dummy connector from the service
    check connector.
    Connect the service check connector terminals with
    a jumper wire.
    stop switch.
    If the ECM has no problem data in its memory, the
    MIL and warning light will come on and stay on.
    If the ECM has problem data in its memory, the MIL
    and warning light will start blinking.
    warning light blink and determine the cause of the
    Jan 2010
    Ft.Lauderdal FL
    Not getting a code it stalls out now. Water pissing out is extremely hot while in the water. Is there a water pump besides the impellar?
    Top Dog west_coaster's Avatar
    Apr 2005
    San Diego CA
    No water pump, the jet pump provides the pressurized water.
    You can take off water hoses at different spots and see how much water flows using the garden hose flushing method. I'd start with the easy ones like the ones on the exhaust side and make sure water flows well.
    05 F-12X
    Apr 2005
    San Diego CA
    Quote Originally Posted by FDNYMEDIC View Post
    No code.
    Check to make sure your exhaust isn't plugged, also check to see if you lose fuel pressure.
    05 F-12X
    Jun 2003
    JACKSONVILLE FL.
    When the overheat [thermometer symbol on dash] trips [ECT trip], it will cause the engine to buck and require a lanyard pull to reset it. It will not set an FI code. If the engine just overheats and instantly dies, it is the MST which is a Coast Guard requirement that an overheated exhaust manifold instantly kill the engine to prevent a fire. It also will not set an FI code.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
