Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    PWCToday.com Is My Home Away From Home bbigfish's Avatar
    Houston
    SXR 1500- how hot is too hot?
    I don't know much about 4 strokes but this motor really runs hot. I have a service manual, but it sais nothing about max temp.
    Red light comes on if oil temp gets too high. But what is too high?
    After hard are motor in 95f air temp and 85f water I have had the engine so hot water sizzles when it hits the cases/ cylinder. Ski runs great, oil looks great.
    My my water lines are clear!
    After looking at at the water flow diagram, their is very little water cooling this motor. Maybe R&D is on to something when they are offering a 5 line cooling system!
    This is ski is awesome! Just need more power Plan on taking temp gun to the water this weekend.
    Thought?
    Thanks to:
    My family &
    Friends
    Frequent Poster Shredder's Avatar
    Jul 2006
    Peoria, AZ
    Re: SXR 1500- how hot is too hot?
    I would think similar to a car 180 + to just over 200 ish . My 4 stroke dirt bikes run 180 +
    Shredder
    Aug 2011
    Texas
    I previouslyhad a STX15F which used the same motor and had no issues. I understand what you are saying but you may be overthinking it. The main thing I do is to do some idle time or slow speed riding after running hard before shutting down the engine to give it time to cool down.
    '16 Seadoo GTX155 / depth finder and ski mode module added
    '17 Kawasaki SXR 1500
    Jan 2009
    Sparks
    The first time I took mine out, I ended up taking it back to the dealer because I thought it was going to seize it was so hot. They checked it out and said everything was good. I just keep riding and everything seems good.
    Houston
    thanks for the feedback!
    I am taking a temp gun next trip out. Will just keep monitoring.
    My Kawasaki dealer told me not to worry about it. Evidently if the oil sensor failed, the ski goes into shutdown mode.
    Thanks to:
    My family &
    Friends
    Top Dog
    Oct 2006
    under a ton of work
    typical 4t oil temps hover around 225 to 245.250 is not unheard of and around 275 it starts to break down.
    Houston
    Quote Originally Posted by restosud View Post
    Wow! Thanks!
    Thanks to:
    My family &
    Friends
    Kawi dumps all the cooling water into the muffler & the fittings are very restricted to keep the motor very hot.
    On 15Fs we sometimes have to open up the exit fittings in order to let the water flow out & let the motor run cooler. What happens is the ski will run fine all day long & then when they drop down to idle the water pressure drops & the water in the motor starts to boil & then it starts shooting stem out the pisser.
    This is in Fla where summer water temps are 80-90 already. All my experience is with the sit downs but I am sure Kawi has done nothing to change it in a standup.
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    4t burns less fuel the less u heat the cooling water. All heat soaked away is generated by burning fuel, less taken away, lil less fuel used. Old lt1 w/reverse flow cooling run pretty hot, always seemed wrong when u popped the hood
    Seadoo & Yamaha use thermostats & Kawi doesnt so they have to restrict the water leaving the motor to get the heat up.
