Results 11 to 20 of 27
    PWCToday Newbie MGD's Avatar
    Jul 2017
    Milwaukee WI
    Re: Sea Doo HX Sport Spec (1st time)
    This one looks a little better.
    Frequent Poster Sev1n's Avatar
    Aug 2015
    Lake havasu
    you need some jettrim
    Jul 2017
    Milwaukee WI
    Yeah but, after I put the engine and pump in it.
    Seat cover and mats are on the long list.
    Carb rebuild kits and fuel lines are on the short list.
    Do you racers remove the fuel filter and or the fuel valve?
    Aug 2015
    Lake havasu
    keep the stock filter, run all new lines from reserve to carb. Forget the fuel valve. replace the needle and seats as well. and use oem carb kits, s/s hose clamps.
    Jul 2017
    Milwaukee WI
    So just cap off the non reserve pick up on the tank?
    Also, keep the factory vent near the fill tube?
    What do you do with the starboard vent through hull?
    Aug 2015
    Lake havasu
    yeah just cap it off. I ran a 1" long line off it, attached a 1/4 to 1/8 brass fitting and used it as a feed for my primer. leave the stock venting
    Jul 2017
    Milwaukee WI
    So the '95 HX has the engine right now. I have oem rebuild kits coming for the carbs
    What jet sizes should I look at when removing choke plates and running open FA's?
    Jul 2017
    Milwaukee WI
    I used a mixture of half water and half muriatic acid to get the stains out of the foot wells.
    Wow, super clean.
    Jul 2017
    Milwaukee WI
    This little beauty arrived today.
    Been waiting on it to button up the pump and exhaust.
