Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
    Feb 2016
    New Jersey
    Pictures of Half Assed Ski Repairs - Let's See 'Em
    I could not find a thread on this topic so I started a new one. I pulled the engine out of an old Kawasaki TS and someone before me used an air line hose coupler fitting to connect the flush kit hose to the cylinder head.
    Re: Pictures of Half Assed Ski Repairs - Let's See 'Em
    If it works then does it matter....
    It's only a bodge job if it fails
    PWCToday Regular mase911j's Avatar
    Jun 2016
    Virginia Beach
    Quote Originally Posted by Kershawman View Post
    Ha! I wonder how he capped it off. Do they make terminating felame ends for that coupler??!!
    Sent from my SM-G930V using Tapatalk
    Jul 2015
    Huntsville AL
    Yeah, there are no rules on NPT fittings!
    My favorite: "deleted oil pump, for premix" = cut the lines and let the oil pump push oil straight into the bilge
    Feb 2016
    New Jersey
    I don't think that fitting works at all. The flush kit hose is 1/2" diameter and the end of the air line coupler is 1/4". Not a lot of water is going to flow through that restriction.
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    Head bolts on a kawi 1500... if it doesn't grip, use silicone... pffft!
    PWCToday Guru Nemo's Avatar
    Aug 2004
    Midwest
    No pics right now but the most typical one I've seen is SAE steel bolts/ nuts installed. Usually rusted to death and threads that are trashed.
    Top Dog
    Feb 2013
    NorCal
    Quote Originally Posted by Nemo View Post
    Hard to find 10x1.25 in metric.. =/
    PWCToday Guru njk4o5's Avatar
    Apr 2006
    Boston, MA
    i always use air line hose for my flush...whats the issue? I have a small coil hose I modded to fit
    01' Sea Doo XPL- solas 15/20, proK filters & Watercraft Magic jet kit, custom water injection, TDR waterbox, R&D 49cc head
    Jun 2016
    Virginia Beach
    Quote Originally Posted by njk4o5 View Post
    How do you get it to mot leak? I figured the QD coupler would leak
