    PWCToday Guru DeMan686's Avatar
    Mar 2009
    Reno
    Fx140 won't plain out
    So my fx140 was running great this weekend and on the third day it wouldn't plain out. It was working so hard to go 30 mph. I checked the plugs number 1 plug was black, 2 plug was perfect in color, 3 plug perfect, 4 plug was clean looked brand new. Swapped 1 and 4 still ran like crap. I hard reset the computer and still same thing. Don't no what it could be? Any help would be great. Do t want to take to the dealer unless I have to.
    May 2013
    Sumter, SC
    Re: Fx140 won't plain out
    Are you getting spark in all cylinders? Bad coil perhaps?
    Check compression & replace all 4 plugs no matter what they look like.
    Mar 2009
    Reno
    Sweet thanks guys I'll try what I guys said.
    Mar 2009
    Reno
    So I checked spark. It is good in all cylinders. I also replaced the spark plugs. Fired it up sounds a lot better. Took it to the lake ran good for about 15 min then it would not go over 35 mph. Plulled the plugs first on is back and wet. The others are perfect. I'm thinking fuel injectors is bad. So I gues time to pull the fuel rail and see what the spray test looks like. I had this same problem two years ago and it was the plug wire where in the wrong order. Dealer fix them and haven't touched them seance. Any else have this issue? Ski only has 89 hrs on it.
    Jan 2006
    Florida
    oil on plug? Check compression
    Mar 2009
    Reno
    Was wondering when I start it now the oil light comes on at idol if i rev it to 1500 or 2000 rpm it goes away. Was wondering if the oil sensor could make it not plain go into a limp mode not going over 35mph?
    Trying to get my hands on a compression gauge to do this ski.
