Waveraider 1100 and solas prop selection Help
    PWCToday Regular destructive's Avatar
    NJ
    Hey guys, Ive been doing some reading on props and just cant seem to fine the correct answer. What i have is a 96 waveraider 1100 with 63m motor, a 150psi head, boysen reeds and stuffers, 44mm blackjack carbs, ported and polished intake and a straight through exhaust, im currently running a solas 13/19 and its great on mid range punch, i really am looking for a setup to get me out of the hole faster. I really only use the ski to jump in the surf. I have another solas prop yb-sc-i 14.5-18
    will that give me more low end or should i be looking at a different model? Seems like every prop description i read gives you more low end punch and more top end speed....im kinda lost and any insight would be greatly appreciated. Again all i care about is getting out of the water as fast as possible.
    Dec 2014
    Re: Waveraider 1100 and solas prop selection Help
    So your running the yd-cd 13/19 ? That impeller is made for a highly modified engine. I don't believe you have enough hp to fully utilize that impeller. Try a YD-CD 12/18. The yb-sci should be a 144mm impeller, and you should have a 155mm pump.
    Have you done any work to the pump and intake grate ?
    NJ
    I have a 144mm stock pump, shimmer for nose up and a scoop grate for riding in the surf. I don’t have a yd cd. I have a yb-sc-i
