Help water in crankcase - Page 2
Results 11 to 17 of 17
    PA
    Re: Help water in crankcase
    You didn't winterize in Canada? Was it stored in a heated space?
    Nov 2016
    Ontario Canada
    We just bought it in March, so, no i did not winterize. The seller said he did but maybe not done correctly.
    Oct 2013
    Ohio
    Before you take it all apart. Pressure test the engine to check for air leaks also. Then pressurize the water jacket t That way you might be able to avoid a complete disassembly. You can inspect the cylinder walls through the exhaust ports and get a look at the crank through the intakes with the reeds removed. This is a good place to have one of those endoscope cameras for your phone.
    Nov 2016
    Ontario Canada
    We have started making the exhaust block off plate out of plexiglass. With that on the water jacket can be pressurized.
    I have never done a pressure test for air leaks, not sure of the steps.
    Oct 2013
    Ohio
    The kit contains block off plates, and a pump. You need to make plates for the intakes, like you are for the exhaust, but they need to be tapped for fitttings, so you can pressurize the engine.
    Nov 2016
    Ontario Canada
    Ok, that is easy. Thanks.
    Nov 2016
    Ontario Canada
    I would guess this is our problem. The gasket between the 2 halves of expansion chamber had failed. Alowing lots of water into the exhaust. A part of this water would end up inside the engine.
