Results 1 to 10 of 17
    Nov 2016
    Ontario Canada
    Help water in crankcase
    we have 2 770's. Had both out a few weeks ago.
    both ran fine. Been back on the trailer since.
    now one has water in the crankcase. Lots of water. Squirting out the spark plug holes when we crank it.
    what to do?
    how did water fill the engine?
    Oct 2013
    Ohio
    Re: Help water in crankcase
    Did you have water in the hulls at any time during the ride? Did you flip that one over? Did you run it on a hose after the last trip out? How long between the last outing and the discovery of the water?
    Nov 2016
    Ontario Canada
    No water in the hull, did not flip. Never ran on a hose.
    i think it sat for 3 weeks.
    But those are the things that would make sence, with water in both cylinders. I was wondering if the normal water in the exhaust could have found its way to the engine after a bumpy trailer ride?
    Oct 2013
    Ohio
    I wish I had more ideas. Have you got it to start yet? I worry now about rust on the crank and bearings now.
    I always start mine after I load them on the trailer to blow out excess water from the exhaust. I have done that with every boat I ever associated with in the last 50 years.
    Nov 2016
    Ontario Canada
    Yup rust on the crank bearings will be really bad.
    It will not run yet.
    I think we should put it on the lawn, flip it upside down. Drain the motor.
    Oct 2013
    Ohio
    Is it possible that you towed it to the loading ramp, before you loaded it onto the trailer? Maybe you used on boat to two the other to the trailer? Or did you actually drive it, under power, to load it onto the trailer?
    Nov 2016
    Ontario Canada
    Drove the ski onto the trailer.
    I am wondering if the exhaust is cracked. Internally, from not being winterized?
    Nov 2016
    Ontario Canada
    The motor is coming out.
    No luck figuring out this driveshaft?
    is it threaded?
    Any help?
    Nov 2016
    Ontario Canada
    Motor is out
    Still do not see where the water was getting in
    Nov 2016
    Ontario Canada
    I have been thinking about the white guey crap that came out of the motor. It was not clear water mixed with oil.
    So i am thinking that you only get this guey stuff if the water and oil are well mixed together. But i dont know if this is true.
    But if the water and oil have to be mixed up then the gue must have been made during the drive. Maybe a water leak into the cylinders??
