2005 stx 12f wide open throttle-is this bad?
Results 1 to 6 of 6
    Jun 2017
    Nevada
    I tried search, but found no answer so i apologize. Bought 2 of these skis, first time owner. will i damage the engine at wide open throttle? they have about +- 140 hours on them, and seem to run good.
    Aug 2010
    Australia
    Re: 2005 stx 12f wide open throttle-is this bad?
    replace the fuel filter !plugs are probably bad as well ,being a four stroke ski they should be regularly serviced as you would with a car , motorcycle , etc , on a side note , check the fuel filler neck is not cracked , this id a common fault with those skis and it allows water to enter the fuel tank , great choice of ski they are very robust and reliable
    modded X2 650
    900 powered custom 650 sx .
    Jun 2017
    Nevada
    okay, i need to order the service manual.
    Sep 2010
    Kent, WA
    Quote Originally Posted by Gsl.shoemaker View Post
    I have the same ski, it's a very robust motor and I can run WOT all I want.
    Make sure it's running good (very sensitive to old plugs) and fresh oil, etc.....
    Regards
    charger_john
    in Kent, WA.
    1996 JS750SXI (sold in 2017!), 2004 STX-12F, 2015 Superjet
    Jun 2017
    Nevada
    thx john
    PWCToday Newbie OR Biomed's Avatar
    Aug 2017
    Pittsburgh
    I am the 3rd owner of a 2003 stx 12f. Bought it with 50, it now has 345hrs on the clock. I run mine wide open all the time. If it starts to hesitate on RPMs replace the plugs. They are very touchy on plugs. Solid unit if its taken care of.
