Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 67
    Resident Guru rhaas's Avatar
    May 2008
    bay saint louis, ms
    Re: BJP Prize Ski Build Thread - JS701 Sleepersaki - Jet Blast 2018
    The 300 ebox mounting must be different than the 440-550. That is the first one I have seen with the 701 kit.
    Looking good. let me know if you need any help.
    RHAAS PRODUCTS
    urethane motor mounts for watercraft... its about time!!
    http://www.facebook.com/#!/pages/Rha...12717472096935
    try our new website
    http://www.rhaasproducts.com/
    stay tuned for more products
    Dec 2005
    Wisconsin
    5
    Quote Originally Posted by rhaas View Post
    Yeah, the 2 drilled but unthreaded holes was odd, because there were 2 other "offset" holes that were used to secure the ebox. And that drilled hole that didn't line up with the bracket from the kit was clearly drilled off-center in the boss from kawasaki.
    WHEN IN DOUBT, GAS IT!
    Dec 2005
    Wisconsin
    5
    Dec 2005
    Wisconsin
    5
    Dec 2005
    Wisconsin
    5
    Dec 2005
    Wisconsin
    5
    Decided to fill in the little side gaps between the pump shoe and the hull with 5200.
    Dec 2005
    Wisconsin
    5
    Get ready for some serious hook up with this pump swap.
    Dec 2005
    Wisconsin
    5
    20170812_133055.jpg20170812_133059.jpg20170812_133103.jpg20170812_133108.jpg20170812_133112.jpg20170812_133121.jpg20170812_133124.jpg20170812_133131.jpg
    Pump is in. I could have used the silicone Rhaas pump seal, but the fit was so nice and snug without it that it was much easier to just do it 650sx style and silicone the front of the pump and wipe off the squish out.
    I changed out the sloppy kawi steering cable ends for yami stainless cable ends and balls.
    Dec 2005
    Wisconsin
    5
    Support bearing in. Will shim this later, if needed once I see how the 701 lines up.
    Dec 2005
    Wisconsin
    5
    New Yami style pole bushing epoxied in place after the holes were enlarged and pole spring added. Zero slop in this handlepole now and much lighter.
