What size Allen socket bolt for "Factory head pipe to exhaust manifold
Results 1 to 10 of 15
    I dream skis GASSEM's Avatar
    Apr 2006
    YULEE, Fernandina Beach
    Like the title says
    what size bolt
    length
    metric ?
    diameter
    i think it's course
    thanks Jeff
    There is a very fine line between 'hobby' and mental illness.
    Apr 2014
    United States
    Re: What size Allen socket bolt for "Factory head pipe to exhaust manifold
    M10 1.25, not sure on the length, but one of the longer yamaha case bolts works great.
    Top Dog octane114's Avatar
    Mar 2009
    charleston,sc
    Rad dudes sale them
    it is what it is . it's all good
    Aug 2007
    Mar 2005
    Santa Barbara, Ca.
    Hard to find locally in SS.
    SE MI
    Fastenal.com has the for around $5 each. M10x1.25x50mm long.
    Resident Guru still standin's Avatar
    Jul 2009
    michigan, KZOO
    BL did you see these in Stainless on Fastenal? couldn't find them in SS.
    -2019 SXR - Unlimited Fixed Steer Conversion- 64.8mph
    -86 X2 - Twin carb 750 swap, blaster pipe etc -
    SE MI
    I purchased mine from them, about 4 years ago.
    Mar 2016
    Central Eastern PA / Central NJ
    For anyone interested, the stock bolts that attach the headpipe to the manifold on the Kawi 650's ( sx, x2, etc) are the correct length (50mm) to use with the Kawasaki Factory Pipe head pipe. The bolts are still available from Kawasaki under part number 92150-3819 and they are $7-$8 a piece. They are strong, stainless, and already have thread locking compound on them.
    If you have a Yamaha version of the Factory Pipe head pipe you will need bolts that are 10mm shorter (40mm).
    Again, as someone mentioned, rad dudes offer nice stainless bolts as well.
    Chicago / Portage, MI
    The 1.25 is a JIS standard (fine pitch) thread. It's hard to find stainless in the US. I did a ton of searching and found a place that had stainless socket head ones a while back for about $5 each. I just checked Fastenal and don't see any, who knows they may be hard/ rare to keep in stock. I have bought black oxide coated steel ones from McMaster, they have them for $6-6.50 for 10 depending on if they're 40 or 50mm.
    Keihin42, are you sure the oem ones are stainless? The ones I have seen would appear to be coated alloy steel if I had to guess.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1995 SJ MINT:
    Worx 205 intake [42.5mph gps]
