Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
    Jun 2011
    Re: 140mm Solas Pump with Concord Impeller
    How did they make the hull 30 lbs. lighter? Is it carbon fiber or did they shave down the fiberglass hull?
    I would also be interested in what type of range you will get from the re-jetting on the GTi as I just acquired the same ski about a month ago.
    The stock BN38I carbs are jetted at 130 Main & 67.5 Pilot.
    What jetting were you thinking of using?
    If at first you don't succeed...
    Then you're NOT Chuck Norris!
    Dec 2011
    Niceville, FL
    I'm starting with 80 lows and 140 highs. Pop off is 28-29 and I'm running an aftermarket flame arrestor. I have a Jet-Pro pipe, it looks like a mini 951 Rossier pipe. I have no idea how it will do but I'll ride it and let it tell me where it wants to go from here. I won't accept sub-stock performance and I hope to out range a Spark.
