Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Dec 2011
    Niceville, FL
    140mm Solas Pump with Concord Impeller
    Came from a 787 X4 racer. Bearings feel perfect. $325 shipped
    Jun 2011
    Re: 140mm Solas Pump with Concord Impeller
    That's really cool !
    What pitch impeller, Matt?
    What would Chuck Norris do?
    Dec 2011
    Niceville, FL
    No clue I just pulled it off the ski. He was running a Spec 2 and a Buckshot head. Looks like it was a limited.
    Dec 2011
    Niceville, FL
    $450 shipped with the R&D nozzle set that came on it.
    Dec 2011
    Niceville, FL
    Bump
    Dec 2011
    Niceville, FL
    Bump. People pay that money for stock setups. This aftermarket setup is ready to bolt on and run.
    Dec 2011
    Niceville, FL
    Pics that work
    As I said before this is a great deal. Bearings are good, vanes look good, prop looks good, run it! Fresh off a 98SPX racer
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    What's the advantage over a brass pump?
    Dec 2011
    Niceville, FL
    Not sure of top speed or holeshot differences because I have not run it myself. It's built like a Skat magnum on the inside with grease instead of the gear oil like in stock Seadoo pumps. The cone is oversize compared to stock pumps and the vanes are thinner and smoother. It has a stainless wear ring and the tolerances are nice and tight compared to stock ones.
    Frequent Poster Lakeside8's Avatar
    Aug 2013
    celina ohio
    so in other words a knock-off skate pump
    Sent from my SM-G930V using Tapatalk
