99 TigersharkTSL 770 Carb help
    Jun 2017
    CO
    Hello,
    I am trying to get this thing up and running, however the previous owner lost the carb for it. I'm having a heck of a time trying to find a replacement for it, as I can't seem to find the right model of carb. If anyone could give me the proper carburetor part number that would be awesome. This is my first jet ski, so I'm pretty clueless on these. Thanks!
    Oct 2013
    Ohio
    Re: 99 TigersharkTSL 770 Carb help
    You have a couple of options. The 770 was a popular engine for Tigersharks. You would not have to get the exact carb. You may be able to find a pair of carbs and manifolds from several different models that will work.
    Your 99 probably had a single Mikuni BN40-38.
    My 98 TSL's have dual Mikuni 38's.
    PWCToday Regular Goodchildren's Avatar
    Jul 2012
    Joliette, Quebec, Canada
    http://www.cafr.ebay.ca/itm/Tigersha...JZSEAp&vxp=mtr
    http://www.cafr.ebay.ca/itm/Tigersha...VZDBIi&vxp=mtr
    check on ebay multiple find in a second, if you take with complete intake you have no problem to fit it on your engine and have better power with a dual carb if they are adjust correctly
    Tigershark Daytona 640 1995
    Tigershark 644 1993
