Results 1 to 2 of 2
    PWCToday Regular skymac's Avatar
    Mar 2007
    Bowling Green, KY
    ECU Drama - Need Help
    Here's what I have: 2008 Challenger 180 215 powered boat. I have a false oil pressure issue.... oil light will come on above 3000rpm and usually gives code P1520 (low oil pressure) I have a manual gauge installed and I have perfect oil pressure. Checked harness, grounds, and oil pressure switch.
    Leaning towards ECU....
    My current installed ECU is #665786
    Seadoo Parts Manual show only these 2 parts for the boat: 664946 and 665787...
    I have the opportunity to buy a working 664946 for $150... Does anyone know the differences? They are all listed for the 2008 215 boat, the one I have 665786, is listed for the twin engine 215 Challenger... mines a single... What gives, any idea?
    Jan 2006
    Florida
    Re: ECU Drama - Need Help
    how high does oil pressure go. Too high will trigger alarm and you will have to replace the regulator on the bottom of the engine. Try a new sender first.
